ouch... coolant issues help needed
Old Jul 26, 2005 | 01:04 PM
rnbguy's Avatar
Default RE: ouch... coolant issues help needed
okay sure ill look for them, so what do these screws do?
Old Jul 26, 2005 | 01:13 PM
CRAZYHAWK's Avatar
They let air come out.
Old Jul 26, 2005 | 01:16 PM
rnbguy's Avatar
okay cool ill try change coolant tomarrow morning if hot air doesnt come out then ill look into that solution youve suggested thanx heaps dood
Old Jul 26, 2005 | 01:17 PM
Jestnomen's Avatar
6th Gear
ORIGINAL: CRAZYHAWK
Yep, correct. Yep air sometimes stays in and blocks the passages. If you cant fit 2 gallons of coolent/water in the system then there is air in there. You may need to add coolant, start the car, bleed it, and add more coolent.
Old Jul 26, 2005 | 01:21 PM
rnbguy's Avatar
excellent, sounds easy so far
Old Jul 26, 2005 | 01:31 PM
Jestnomen's Avatar
6th Gear
Don't jinx yourself. [8D]
Old Jul 26, 2005 | 01:35 PM
rnbguy's Avatar
now im worried :P
Old Jul 26, 2005 | 10:57 PM
  #18
david9999's Avatar
Need to find where the coolant is going. Check for external leaks and also check the oil cooler.
Old Jul 26, 2005 | 11:00 PM
  #19
rnbguy's Avatar
how do i check the oil cooler? what is an oil cooler by the way?
Old Jul 26, 2005 | 11:20 PM
  #20
rnbguy's Avatar
hey i think i found the problem, the plug that connects to the bottom of the coolant resevour was discounected, i just connected it, is there anyway it should go in, because i just plugged it in as soon as i heard the clicking noise, i dont want to run the car before i ask you guys to see if i should plug it in the other way around it has has a green wire with a yellow stripe and another brown wire...?
also I cant find the red **** to drain radiator, without taking the bumper off which i dont want to do, any tips on how i can find it?
