Overboost / No Boost Problem HELP
Old Jan 9, 2012 | 11:21 PM
KyGN87's Avatar
Exclamation Overboost / No Boost Problem HELP
06 A4 2.T Quattro 86,000mi. bone stock
Under moderate to heavy accelleration (typical aggressive on ramp merging) the car will pull hard at first then fall flat on its face, almost as if it overboosts and goes into limp mode (but no gauge to verify boost spike). After that happens it will remain way down on power until the engine is restarted, then it runs great until the next time I boot it. Seems to happen easier in the higher gears/under load. When it happens the car still runs smooth, seems fine on gas and is quite driveable.
CEL was already on for an evap code previously and I dont have access to vag com so I cant be sure if this problem is accompanied by its own code.
Any input? N75/wastegate actuator/related vac hoses? Im quite familiar with turbos (80's Buicks actually), new to Audis.
R4zzy
Jul 21, 2013 07:35 AM
Desert Fox
Dec 26, 2010 11:36 PM
200tq
Jun 3, 2009 08:16 PM
TT_GUY
Mar 30, 2008 07:54 PM
endle55
Jul 29, 2006 03:42 AM
