Overheating??
Old Apr 11, 2007 | 01:13 AM
MotorsportA59's Avatar
Default Overheating??
Well I haven't had my a4 for too long and I have now encountered my first problem. I can start it up and it runs fine idleing, but as soon as I start to drive the temp and oil temp raises. The oil temp goes up a bit and the engine temp goes all the way up. The car's coolent is good and the oil has just been changed. When I open the hood the engines doesn't really seem to hot. I booked it into the dealer but I couldn't get in for a week, so any help in fixing it sooner then that would be great. Thanks.
Old Apr 11, 2007 | 01:15 AM
Default RE: Overheating??
also I put a baileys diverter valve on a few days ago but i doubt that would have anything to do with it
Old Apr 11, 2007 | 01:16 AM
1234RiNgs's Avatar
oil temp sensor and engine temp sensor.
those 2 are pretty common to fail
Old Apr 11, 2007 | 03:34 AM
zoti's Avatar
Also make sure you have no air in the colling system.
Old Apr 13, 2007 | 01:45 AM
well i got it in early to the dealer and apparently it was the fuel pump. sounds kinda weird to me, but im new with audi's so i don't know
Old Apr 14, 2007 | 01:54 AM
Vaudi's Avatar
Thats wierd
Old Apr 14, 2007 | 09:55 AM
david9999's Avatar
There is no way that the fuel pump will cause any engine to overheat. This isn't a "I;m new to Audis issue". Learn something about engines.
Either it is the water pump, or the engine thermostat is stuck shut. Have you checked the top and bottom radiator hoses to see if they both get hot?
There is an oil cooler which used coolant to keep the oil temperature OK. Thus if the coolant isn't circulating the oil gets hot too.
If the dealer really means
katcoota
Mar 8, 2009 11:25 AM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
