overheating issue
Old May 31, 2006 | 12:16 PM
LuckyCharmsUXZ's Avatar
Default RE: overheating issue
ok, i figured it would be the right part, its just that the majority of the temp sensors i sell have threads, they did on my chevy that i had b4 the audi, so i just wanted 2 make sure before i took the thing apart, thanks guys
Old May 31, 2006 | 12:18 PM
clconversion's Avatar
o yea ok sorry other cars can be threaded for sure actually that would be a lot eaiser as well damm Audi's haha anyone ever try and replace that sensor on a VR6 good luck haha
Old May 31, 2006 | 12:24 PM
techbod's Avatar
remove coolant filler cap and run engine till the fan cuts in if the coolant blows out and the fan doesn't cut in then it could be a fan fuse/relay, if you make the fan permanently on and the water shoots out then suspect head gasket
Old May 31, 2006 | 10:12 PM
so i just finished changing the temp sensor.... and it didnt work.... there is still an overheating issue..... the hoses are hot after the car has been running for a while so the t-stat is fine right? but i also noticed that the pass side fan wasnt turning on even when the temp alarm turned on inside the car.... so that makes me think it is a aux fan relay/switch.... im just gonna bring it to the shop 2morrow morning....
Old May 31, 2006 | 10:25 PM
acetrebo's Avatar
Well, I would think it would be throwing codes if it was the temp sensor.
Sounds like thermostat ok.
The passenger side fan is for the ac condensor I believe, so that shouldnt matter. Is the main fan turning?
Is your fluid level correct?
It sounds to me like you need to bleed air from the system.
If you want instructions do a search, or ask here. Its a good possibility this is the problem.
Old Jun 1, 2006 | 12:39 AM
the fluid level is correct and the reg fan is turning like it is suppossed 2 be, i dont kno what else it could be... im stumped, so im just gonna break down and bring it to the shop... thanks for all the help guys
Old Jun 1, 2006 | 01:37 AM
toyolla86's Avatar
you should take the guys advice and bleed the system first. i would rather save the money before bringing it to someone who i dont trust with my car.
Old Jun 1, 2006 | 01:51 AM
  #18
immgeorge's Avatar
I had a problem with overheating too. My car was throwing temp warnings, but my temp guage was fine, my coolant was fine, and my fans were fine. It's been in the shop for a day now and they still haven't found the problem...
Old Jun 1, 2006 | 02:41 AM
  #19
blake's Avatar
The ac condencer fan should turn on when its hot (not moving), mine did the same thing. check the fuse under the steering wheel ( not the side panal ) and replace it. its kind of hard to get too but what is not on these cars.... hope that helps
Old Jun 1, 2006 | 11:05 AM
  #20
the guy i bring my car 2 is a close friend of mine, he has done pretty much all the mechanical work that i cant do on my car, and he has been doing it for a long time.... you guys will prob end up being right, but i will be sure 2 keep u informed when i get it back
