Oxygen sensor and ECM HELP!!!
Old Nov 12, 2005 | 02:18 AM
NoFlyZone's Avatar
Default Oxygen sensor and ECM HELP!!!
I'm screwed.. unless somebody can help? Dealer effed up my2000 A4 TQ big time. Chasing electrical problems big time. Replaced 3 yes three Oxygen sensors (upstream and downstream) but still throws the 17536 codes and loses performance. Thinking now is that my ECM is hosed. Worked yesterday after another new sensor (upstream) great, then died (check engine light-no turbo) after 15 miles. I'm crazy and broke from buying these sensors. Possible ECM issue?? Help!!
Old Nov 12, 2005 | 05:36 PM
Shaunp05's Avatar
Default RE: Oxygen sensor and ECM HELP!!!
well first if the replaced parts and said the problems fixed
but its stilll there take it back to them
Old Nov 12, 2005 | 08:37 PM
Jestnomen's Avatar
6th Gear
Why would you have to pay for the O2 sensors if it didn't fix the problem??
Old Nov 12, 2005 | 09:23 PM
techbod's Avatar
that's because code 17536 P1128 is nothing to do with o2 sensor though it will effect the readings, problem is long term fuel trim, entire speed/load range, bank 1 - system too lean, possible faults are - fuel pressure/pump, injector(s), intake/exhaust leak, AIR system, hose leak
Old Nov 13, 2005 | 02:22 AM
Shaunp05's Avatar
If thats the case then you have to figure out if the Computer is getting bad Info
to make it run lean or the computer gets tthe correct Info but sending the wrong signal
to the injecter duty cycle
By the way is this in Closed Looop ?
drft1
Jul 5, 2010 12:18 PM
spiney
Jul 15, 2009 10:18 AM
j_ripper19
Sep 30, 2008 09:57 PM
brent07
Jan 19, 2007 03:57 PM
david9999
Aug 11, 2005 07:23 PM
