P0118 - Engine coolant temperature circuit, high input
Old Sep 25, 2004 | 06:01 PM
gregp1962's Avatar
Default P0118 - Engine coolant temperature circuit, high input
I'm getting a CEL with a code; P0118 - Engine coolant temperature circuit, high input. Is this more likely the wiring or the sensor? Does anyone know where the coolant temp sensor is?
Old Sep 25, 2004 | 06:38 PM
Jestnomen's Avatar
6th Gear
Default RE: P0118 - Engine coolant temperature circuit, high input
Sounds like you just need to replace the ECT sensor.
link 1
Link 2
Old Sep 25, 2004 | 08:31 PM
gregp1962's Avatar
Thanks Jest. But, I'm wondering why it says "coolant temp high" when the gauge doesn't say high.
Old Sep 25, 2004 | 08:47 PM
Jestnomen's Avatar
6th Gear
You said "hi input" not high temperature.
Old Sep 25, 2004 | 10:30 PM
David_K's Avatar
How many miles does your car have? It might be a good idea to change the sensor.
Old Sep 26, 2004 | 11:41 PM
Doose's Avatar
Well, this is the way it was explained to me when I replaced mine. The ECT sensor is what reads the coolant temp when the car is VAGed. It's not tied in to the temp guage inside the car. If you VAG the car and the ECT reads high coolant temp and your guage still reads normal, it's time to replace the the ECT sensor.
Old Sep 26, 2004 | 11:55 PM
David_K's Avatar
I'll say so.
Old Sep 27, 2004 | 01:43 AM
Doose's Avatar
You mean coolant temp is a touchy subject with you?
Sorry, that was wrong, but you teed it up for me so nicely!
How's the build going?
Dan2012A6
Feb 24, 2014 02:10 AM
phil.k
Jul 17, 2013 01:19 PM
dyazdani
Dec 24, 2010 02:02 AM
Red_sapphire89
Mar 8, 2008 10:19 PM
AudiTurbo
Aug 22, 2007 11:32 PM
