P0117...Engine Coolant Temp Circuit Low Input.PLEASE HELP!!!
Old Aug 17, 2007 | 08:40 PM
AudiTurbo's Avatar
Default P0117...Engine Coolant Temp Circuit Low Input.PLEASE HELP!!!
Ok this happened out of nowhere, and the temp gauge is burried, And when I turned on th heat on full blast it wasnt that hot..Do you think that I Should change the sensor, or what?
Old Aug 18, 2007 | 12:35 AM
ee99ee's Avatar
Default RE: P0117...Engine Coolant Temp Circuit Low Input.PLEASE HELP!!!
You got a stuck thermostat
Old Aug 18, 2007 | 06:22 AM
CRAZYHAWK's Avatar
Check the G-12 fluid reservoir.
Old Aug 18, 2007 | 01:08 PM
AudiTurbo's Avatar
Well I did, and I even put a new thermostat in it and nothing is happening..The car will go to about half way and stop, then start to go toward the H..I dont know if it is the sensor, or could it be a water pump?
Please just let me know what you all think.
thanks!
Old Aug 18, 2007 | 01:24 PM
auditech79's Avatar
Hold on a minute, are you saying the temp on the gauge doesn't rise, or are you saying its slowly going towards the H which means its overheating?
Old Aug 18, 2007 | 02:06 PM
AudiTurbo's Avatar
Sorry I was typing fast..Yes it is overheating, but when I got it scanned it said Engine coolant temp low circuit input..
Old Aug 18, 2007 | 02:22 PM
auditech79's Avatar
The fault code is not gonna have anything to do with it overheating, what you need to do is make sure its really over heating. You need to get a temp gun or see if the coolant is actually getting that hot by feeling the hoses. If it is overheating the water pump is bad because you already did the thermostat.
As for the fault code its probably a bad sensor. Change the coolant temp sensor because those are relatively cheap anyway, if that doesn't fix the fault code the G 12 sensor inside the coolant expansion tank is bad.
Old Aug 18, 2007 | 02:34 PM
AudiTurbo's Avatar
Well this just started happening out of nowhere..Are we talking about the sensor on the back of the motor?
Has a prong coming out of it, and has a 4 **** plug in...so water pump?
Old Aug 18, 2007 | 02:37 PM
auditech79's Avatar
Water pump is probably causing the overheating concern, they are made up of a plastic wheel inside the engine that breaks off, this will cause the temp to slowly rise because the coolant isn't flowing like it should. You should be getting the water pump fixed before anything else, fix that and erase all your faults. If the fault code doesn't come back and the temp gauge works fine after the repair don't worry about it.
Old Aug 19, 2007 | 01:35 AM
AudiTurbo's Avatar
Ok man thanks...But even after I cleared the codes, could it still be just a sensor, or just a water pump....I guess im going to get the water pump changed then..
