P0171"System Lean; Bank 1"
Old Nov 15, 2006 | 12:44 AM
01A4T's Avatar
Default P0171"System Lean; Bank 1"
well guys after a previous post of mine(in which many of you encouraged me to get it scanned) i decided to do that at the local autozone. i got the code "P0171" Bank one is running lean. any ideas on what could be the problem? could it be almost anything? anybody had this code and what was the outcome/solution. any help would be greatly appreciated. am i going to have to go to a stealership?
-Nick
Old Nov 15, 2006 | 12:52 AM
01A4T's Avatar
Default RE: P0171"System Lean; Bank 1"
lol, i just searched and probably should have before i posted my topic, but i was eager to ask you guys what you thought. any insight besides cleaning the maf(also where is it located)?
Old Nov 15, 2006 | 01:03 AM
01A4T's Avatar
well, after my dummass did some more searching i saw a thread about the vacuum line near the top of the intake manifold.....sure enough its all frayed and messed up with a clamp missing now. SOOOOOOOO my legitimate question is what do i ask for when i go to the dealer in the morning? and will this hurt my car too much when i drive it there?
Nick
Old Nov 15, 2006 | 01:37 AM
turbo kraut's Avatar
Tech Guru
got the same code, take a pic of where the hose is
Old Nov 15, 2006 | 01:55 AM
acetrebo's Avatar
Just take a section of it with you, and go to any auto parts store, and buy a similar piece of hose. 4ft should be more than enough, and leave you some for the next time, or another repair.
Old Nov 15, 2006 | 02:07 AM
01A4T's Avatar
Thats a good idea ACE. and to Turbo Kraut.......sorry i dont have a digital camera believe it or not but if you want to find it, it is very apparent. i opened my hood, and just look at the intake manifold. there are 4 channels of the manifold. they look like bars. look at the top "bar" of the intake manifold and you will see a small hose........ in my case it was very frayed and messed up. it is very hard to miss. Hope that helped.
Old Nov 15, 2006 | 11:49 AM
CRAZYHAWK's Avatar
You can drive with a vacuum leak. If it's the L shaped hose
between the G-12 reservoir and the intake manifold, remove the 3
screws that hold the reservoir to make room to work.
Old Nov 30, 2006 | 01:35 AM
TURBEAU's Avatar
Yes, definitely check for the vacuum hose coming off the intake manifold. After installing a brand new air mass sensor, I threw the P0171 code again and then found this thread. To bad it wasn’t the other way around. Anyway, here a pic of what it looks like. I know it’s a little late, but I figured it couldn’t hurt.
Old Nov 30, 2006 | 02:01 AM
01A4T's Avatar
TURBEAU, thanks alot for the pic. this was my exact problem and my hose looked almost identical. i went to autozone, and 2 dollars later...............problem solved. i know i saw another new thread about this problem and hopefully it will help the other guy out.
Gordon Gekko
May 29, 2013 11:50 PM
BesI
Aug 27, 2012 03:02 AM
boostin_A4
Feb 24, 2010 02:17 PM
MatDHan
Dec 14, 2008 09:36 AM
Tsumik
Sep 19, 2007 11:22 PM
