P0171
Old Oct 7, 2006 | 08:16 PM
J_Charisma's Avatar
Default P0171
the code P0171 says my car is running too lean, wt can i do about it
besides, whenever i turn on the car, there is some tapping noise behind the engine, sounds like coming from a valve
wt is that??
Old Oct 7, 2006 | 08:29 PM
Jeff's Avatar
Zombie Defense Force
Default RE: P0131
did you clean or replace the maf?
Old Oct 7, 2006 | 08:31 PM
J_Charisma's Avatar
Default RE: P0131
is maf stands for air flow meter??
Old Oct 7, 2006 | 08:41 PM
ADubyaD's Avatar
SoCal Crew Member
Default RE: P0131
the maf is the mass air flow sensor, i think on your 1.8's its in your airbox, clean it with electronics cleaner and let it dry for a day, then drive it, be careful, very fragile
Old Oct 7, 2006 | 08:46 PM
J_Charisma's Avatar
Default RE: P0131
but when i check the code, it says "Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1"
in which there is nth to do with maf
so im confused......
Old Oct 7, 2006 | 09:03 PM
Jeff's Avatar
Default RE: P0131
well from what you told me that your cel came on after you put a new air filter in. so my guess is that you had an oiled filter and some oil got onto the maf and so now you need to clean it
Old Oct 7, 2006 | 09:07 PM
J_Charisma's Avatar
Default RE: P0131
okay, but without cleaning it, is it still fine to drive around like that??
Old Oct 7, 2006 | 09:10 PM
J_Charisma's Avatar
Default RE: P0131
dude, i give u the wrong code, it should be P0171
Old Oct 7, 2006 | 09:29 PM
Jeff's Avatar
Default RE: P0131
MAF sensor
Old Oct 7, 2006 | 11:03 PM
J_Charisma's Avatar
Default RE: P0131
i just finished cleaning the maf and the light is still there
is there anyway i can reset the DTC and turn the light off??
