P1106
Old Feb 26, 2007 | 10:53 PM
brandons34's Avatar
Default P1106
What does this code mean?
Old Feb 26, 2007 | 11:11 PM
onepoint8tee's Avatar
Default RE: P1106
P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak A
Your pre cat 02 sensor on the drivers side cat is probably shot. If you dont know how long the code has been stored, clear it and see if it comes back. If it caused a CEL, thenits probably like i said. DED.Its the first 02 sensor in the cat, being the sensorclosest to the engine block/manifold. Or maybe its not in a cat, but in a down pipe. Whatever... You know what I mean. First 02 sensor in the exhaust closest to the engine on the drivers side which is bank 2 (B2). Your V6 engine is shaped like a V. The left side of the V (passanger side) is B1 and the right side of the V (drivers side) is B2. Sorry for the elaborate explanation.
Old Feb 27, 2007 | 12:11 AM
lfab500's Avatar
Default RE: P1106
Had the same thing a year ago. Turned out to be a hole in the exhaust right around the O2 sensor. $15 weld job...good as new
Old Feb 27, 2007 | 12:32 AM
brandons34's Avatar
Default RE: P1106
could this be causing my engine to misfire? I have two cylinders misfiring?
NYankee
Jul 18, 2010 02:16 PM
hernieA4
May 1, 2010 03:46 PM
colm92116@yahoo.com
Apr 14, 2009 03:06 AM
Red Baron 97
May 16, 2007 10:48 AM
Topdown
Apr 25, 2007 05:29 PM
