P1559 Error Code
Old Nov 2, 2005 | 08:40 PM
brogenville's Avatar
Default P1559 Error Code
Hey guys, got my vag-com today, what a tool! Anyway, the reason I bought one was because the car had always had a bit of a low idle, causing the a judder in the cabin on idle. I thought it was a mis-fire, so I changed leads and plugs, but sadly no change. Well, the vag-com brought up error 17967/p1559, which as I understand is "Idle speed control throttle position adaption malfunction". I have had a good look through the forum archives, but couldn't find anything specifically relating to this problem. Any ideas? Is my "Throttle valve control part (J338)" knackerd? I did a TBA recently after taking my car out of storage, so Im assuming that that wont do anything.
As ever, your wisdom is appreciated.
Cheers, Rob.
Old Nov 3, 2005 | 01:30 AM
Jestnomen's Avatar
6th Gear
Default RE: P1559 Error Code
I know you said you did a tba, but did you do the vagcom one?
http://www.ross-tech.com/vag-com/cars/throttlebody.html
Old Nov 3, 2005 | 03:06 PM
Not yet, my Vag-Com isnt fully activated yet, so havnt been able to. Would you expect it to work any different to the car's own tba?
Old Nov 3, 2005 | 03:18 PM
Jestnomen's Avatar
6th Gear
Well sometimes the key in the ignition method doesn't work, in fact quite often it doesn't for whatever reason.
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
love the booB5
Feb 29, 2012 10:06 PM
love the booB5
Sep 8, 2008 06:16 PM
tartan rob
May 12, 2003 01:35 PM
