partial throttle stall?
Old Jan 18, 2006 | 02:35 PM
quattrosedan's Avatar
Default partial throttle stall?
hey guys, Im started having some trouble recently. When ever I partially accelerate, as in 5-12psi, with like 50 percent throttle, if I let off the gas, the car jerks really bad. I believe that I have a bad dv, but Im not sure. I was just going to run it by you guys to see what you thought. I am going to check it next weekend. Thanks ahead for any input!
Josh
Old Jan 18, 2006 | 04:43 PM
BadLuckAudi's Avatar
Default RE: partial throttle stall?
Either a bad Dv or you have a vac leak some where.......
Old Jan 18, 2006 | 04:49 PM
onepoint8tee's Avatar
ORIGINAL: BadLuckAudi
Yeah what he said.. Id guess that your DV is serviceable and they tend not to break, but may perform badly if it needs cleaned out or an adjustment... I bet its a vac line leak.. Just replace all your vac lines to rule it out, its good preventative maintnance even if thats not the problem.
Old Jan 19, 2006 | 12:37 AM
trailboss's Avatar
ORIGINAL: quattrosedan
Josh
It has to be something with the chip I think, my car will do it every now and then and i have the same setup. I am going to contact ATP because i know droors had a problem on AZ. I will be installing an EBC or mbc soon.
Old Jan 19, 2006 | 12:39 AM
Jeff's Avatar
Zombie Defense Force
whens this happens does ur EPC light come on?
Old Jan 19, 2006 | 12:41 AM
trailboss's Avatar
nope
Old Jan 19, 2006 | 12:45 AM
Jeff's Avatar
cus this happens to me if im going like 50 up a mountian pass at high elevation, if i get in and out and then back into boost to fast then my car will stall sometimes, well not stall the epc light will come on and i just loose throttle but still have power everything. i just turn the car off and then back on real fast and its back to normal
Old Jan 19, 2006 | 12:52 AM
trailboss's Avatar
you have a mbc or ebc
Old Jan 19, 2006 | 05:11 AM
Jeff's Avatar
i have a turbonetics mbc
Old Jan 19, 2006 | 06:59 AM
Mine does a very similar thing but i have a giac chip i dont know maybe ill call and ask them whats up
