Pick up screen and oil pump
Old Feb 28, 2005 | 08:42 PM
PaulA4's Avatar
Default Pick up screen and oil pump
My car is running 1bar at idle and 4 bar at 3000rpm when it should be running 5-7 bar, oil pump or blocked screen?
Old Feb 28, 2005 | 09:28 PM
CRAZYHAWK's Avatar
Default RE: Pick up screen and oil pump
1 bar = 14.5 pounds per square inch
Old Feb 28, 2005 | 10:44 PM
1.8t20v's Avatar
Im running about the same. 1.5-2bar at idle and over 2500rpm right around 5bar. Its been like that since I have had the car at 34kmi, im at 115kmi now. I assumed that was normal.
Old Feb 28, 2005 | 10:57 PM
CRAZYHAWK's Avatar
My Chilton Manual says:
1.8t 29 psi minimum 2000 rpm
2.8 SOHC 15 psi minimum idle
2.8 DOHC 29 psi minimum 2000 rpm
Maximum All Engines 101 psi
Old Mar 1, 2005 | 12:25 AM
Doose's Avatar
What engine, what year? Had the same problem on my 2000 1.8t. Search "oil sump screen".
Old Mar 1, 2005 | 09:19 AM
PaulA4's Avatar
It's 96 AEB T, the idle pressure is fine, but the fast idle (3k rpm) is down, i wondered if a duff pump causes that or a blocked screen?
For the AEB the specs are..
Idle pressure 14.5 - 50.75 PSI
Fast Idle (3k rpm) 72.5 - 101.5
I'm getting 58 PSI @ fast idle and only 14 PSI @ normal idle.
If i change the screen or access it to clean it, might aswell change the pump anyway right?
Old Mar 1, 2005 | 09:27 AM
david9999's Avatar
Is this off your instrument cluster, or off a measuring block or an external oil pressure gauge?
Old Mar 1, 2005 | 09:44 AM
PaulA4's Avatar
Measuring system fitted into the block.
Old Mar 1, 2005 | 10:41 AM
CRAZYHAWK's Avatar
Check with a dealer. They may cover sludge for your year. You'll need proof of oil changes.
Old Mar 1, 2005 | 11:00 AM
PaulA4's Avatar
Was that a specific recall then?
I'll give them a call but the service guys at mine don't know their *** from their elbow.
