Please Help ASAP
HI guys,
I have tried to start my car this morning.
I can hear the starter spinning but engine doesn’t start or doesn’t even give any sounds of trying to start. Lights in the car are turning off when I try to start as well.
The car is: Audi A4 V6 Auto, 2003
Please help me to resolve the problem.
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0003
Coding: 0016751
Shop #: WSC 63351
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0001002
Shop #: WSC 63351
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 03: ABS Brakes
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04497
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 17: Instruments
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
2 Faults Found:
00668 - Supply Voltage Terminal 30
01304 - Radio
Address 36: Seat Mem. Drvr
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
07-10 - Signal too Low - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
5 Faults Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
00958 - Key 4
35-10 - - - Intermittent
00932 - Electric Window Motor: Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01331 - Door Control Module: Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
1 Fault Found:
Address 56: Radio
Controller: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01205
Shop #: WSC 02610
No fault code found.
End --------------------------------------------------------------------------------------------------[/align]
i tried a new bettary no luck, also i cleared all the codes and the one code that left is [/align][/align]
Control Module Part Number: 8E0 820 043 L
Component and/or Version: A4 Klimaautomat 1116
Software Coding: 00000
Work Shop Code: WSC 63351
1 Fault Found:
27-00 - Implausible Signal[/align]
1 Fault Found:
Here are some changes that happened since the last time car was running. Outside temperature dropped and I also put full tank of gas before coming home and putting car in the garage. Just in case it will help.
It seems to be that there is no sparks coming: how can I check it on this car and this type of engine?
I can’t think of anything else right now.
Thanks for your help guys.
Man, it is a second day that the car won't start. I have tried several times, with two new batteries.
Interesting thing is that power is going off for couple of seconds when I turn the ignition on.
[/align]
[/align]
