plugs under our seats?
Old Feb 5, 2006 | 05:39 AM
csmithblues's Avatar
Default RE: plugs under our seats?
Do you have wiring Diagram?
Old Feb 6, 2006 | 12:30 AM
rnbguy's Avatar
to be honest, im wishing i did, i looked under the seat and cant find plugs for em, do they connect to eachother?
Old Feb 6, 2006 | 01:00 AM
headshok2002's Avatar
I think there is a bracket that faces forward... so if you look under the seat, at the front of the seat... you might see some plugs there. But yeah... If the airbag light is ON in the dash... then these plugs are likely the culprit! If you plug them back in, you'll still have to get the car hooked up to a vag-com to get rid of the light. Disconnecting the battery for 30 minutes or so MIGHT get rid of it, but I doubt it.
Old Feb 6, 2006 | 03:37 AM
rnbguy's Avatar
sorry im hopeless at explaining things sometimes, the air bag is OFF, even when i put the red's on, the air bag light is STILL OFF, never goes ON.
so it is OFF always...
Old Feb 6, 2006 | 04:17 AM
Karl's Avatar
Do your heated seats work? because I have that same connector.. and its either for heat, or or power to the seat
Old Feb 6, 2006 | 04:50 AM
rnbguy's Avatar
i dont think i have heated seats...
Old Feb 6, 2006 | 09:14 AM
techbod's Avatar
same wiring loom fitted to all the cars most are extras for higher spec cars, if you don't have electric seats/heaters/lumber/air bags the wiring will still be there but obviously not connected, air bag dash light and ABS should come on when ignition turned on but engine not started then they should go off in approx 4 seconds if not check if the bulbs have been removed because of a fault ( a common cheat by sales to sell cars so you don't see any problems on the dash that could spoil the sale )
Old Feb 6, 2006 | 10:49 AM
  #18
If you don't have power seats, the plug will not be there for power... truuust me. I put S4 seats in my car, and there was no plug.
Old Feb 6, 2006 | 11:32 AM
  #19
techbod's Avatar
that depends on the age/model surely, they aren't going to make a different loom for a car dependant on model of the same or near age unless the shape changed
Old Feb 6, 2006 | 11:59 AM
  #20
CRAZYHAWK's Avatar
To check the airbag light, turn the key part way. do not start. The airbag light should be lit.
