PO411/secondary air inj sys incorrect flow
Old Nov 9, 2005 | 10:37 PM
TeenAudi's Avatar
Default PO411/secondary air inj sys incorrect flow
Just got a 2001 A4 1.8T. After one week, CEL comes on and OBD gives me this code? Any one know where to start? Thanks for your help...Courtney
Old Nov 10, 2005 | 05:19 AM
techbod's Avatar
Default RE: PO411/secondary air inj sys incorrect flow
incorrect flow detected
check air pump. air valve, air solenoid
Old Nov 10, 2005 | 12:24 PM
Jestnomen's Avatar
6th Gear
I PMed you a pdf on checking the combi valve teenAudi.
Old Nov 10, 2005 | 12:46 PM
clconversion's Avatar
or could be just a vacuum line broken but yes I had the same problem on my A4 and it was the combi valve
Old Nov 10, 2005 | 01:23 PM
audi2poin8kid's Avatar
ORIGINAL: clconversion
definitly check your vacuum lines. i had the same light and it was one of the vacuum lines.. so far so good.. no more check engine light.
Old Nov 10, 2005 | 01:41 PM
Jestnomen's Avatar
6th Gear
Here is a diagram...
#7 is the combi valve. #29 is the secondary air pump. There is also a fuse in the ECU box apparently.
Old Nov 10, 2005 | 03:05 PM
TeenAudi's Avatar
thanks for all your help!
Old Nov 10, 2005 | 03:15 PM
TeenAudi's Avatar
Can I damage the car if I don't get this fixed for a few days?
Old Nov 10, 2005 | 03:22 PM
Jestnomen's Avatar
6th Gear
nah you'll be fine. It's just for emissions on startup.
Old Mar 15, 2010 | 02:05 AM
moore.1289's Avatar
Where is the ECU box. I have read that it is on the drivers side, but none of the descriptions have really been specific enough for me to track it down.
