power steering
Old May 20, 2005 | 08:45 PM
2.8AudiA4's Avatar
Default power steering
ok i need help with this power steering it is making that winding niose and when i checked it the fluid is full but its foam looking like there is air it in. i need to know if there is a way to drain this pump so i can fill it up again to make sure its dead of not thank alot
Old May 20, 2005 | 08:49 PM
Jestnomen's Avatar
6th Gear
Default RE: power steering
The easiest way is to remove the drain lines from under the reservoir. Replenish the tank with fresh Pentosin 11s, drive for a few days and repeat once again. That should flush out most of the system. It wasn't filled with non pentosin fluid recently was it?
Old May 20, 2005 | 10:05 PM
2.8AudiA4's Avatar
no it wasnt it has been a while maybe like 5 months since i refilled
Old May 20, 2005 | 11:32 PM
david9999's Avatar
Bubbles sounds like a puncture or leak somewhere.
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
