Power Steering Fluid
Old Jan 23, 2006 | 03:42 PM
thndrlight's Avatar
Default Power Steering Fluid
What do you guys recommend. I have a 99.5 A4 Q1.8T and need some power steering fluid now, but all the local parts stores say they don't have anything for it, and I am quite a ways from a dealership. Any help is appreciated.
Old Jan 23, 2006 | 03:48 PM
black991.8tq's Avatar
Default RE: Power Steering Fluid
i got mine from lee auto parts, its made by pentosin and is called chf, its in a white can with green letters. its like 25 a can
Old Jan 23, 2006 | 04:51 PM
brrman's Avatar
yep, Pentosin is OEM replacement - However you should be using the Pentosin CHF 11S green can with red letters
The white can (CHF 7.1) is not synthetic fluid and is for older models (up to 1989). I would replace it quickly black991.8tq.
[IMG]local://upfiles/359/2720F8CEC5B349C3895F4E9745CF933C.jpg[/IMG]
Old Jan 23, 2006 | 05:22 PM
well ive been running it for over a year now, i did not know that it was not the correct fulid
Old Jan 23, 2006 | 06:13 PM
brrman's Avatar
ouch, dude. Probably not catastrophic, but if you continue to use it your seals will most likely corrode a lot sooner, and your pump might decide to die. Our cars specify synthetic fluid.
You should flush your system - you CANNOT mix the two types.
Killuminati
May 23, 2013 09:18 AM
moeron7
Jan 9, 2008 08:09 PM
bronxblaza117
Jan 9, 2008 06:00 PM
thrax982
Mar 31, 2005 10:15 PM
