power steering fluid
Old Mar 10, 2005 | 01:44 AM
redaudia4's Avatar
Default power steering fluid
I checked my power steering fluid level when recently doing some work on the car and found the fluid to have a burnt smell. Is this normal fluid level was fine. Looked around couldn't find any other posts on the matter.
Old Mar 10, 2005 | 01:46 AM
Jestnomen's Avatar
6th Gear
Default RE: power steering fluid
what color is the fluid? Is it dark? Burnt smelling fluid usually means a failing power steering fluid pump.
Old Mar 10, 2005 | 01:50 AM
redaudia4's Avatar
It was a light brownish color. Just had the pump replaced about a year ago. Pump has been whining but only when it is 15 or below
Old Mar 10, 2005 | 01:54 AM
Jestnomen's Avatar
6th Gear
the fluid should be green. You may want to flush the fluid with some new.
Old Mar 10, 2005 | 02:05 AM
redaudia4's Avatar
Any special procedures I should use when flushing. Fluid definetly is not green.
Old Mar 10, 2005 | 02:11 AM
Jestnomen's Avatar
6th Gear
If you get under your car, you will notice two lines going to the reservoir. Remove them both and drain the tank and the lines as best as you can. Reconnect the lines and fill with Pentosin 11s. Drive the car for a week or so and repeat the process.
Old Mar 10, 2005 | 03:08 AM
apg96's Avatar
i replced my fluid and the new fluid was brown. (i also still have a whinning sound when cold (in so cal that 55 or below))
Old Mar 10, 2005 | 10:11 AM
Jestnomen's Avatar
6th Gear
You replaced it with oem? Pentosin 11S is green.
Old Mar 11, 2005 | 02:01 AM
apg96's Avatar
yea i went to the dealer and bought power steering fluid.
Old Mar 22, 2005 | 07:27 PM
sdaudi's Avatar
i'm also hearing the whining noise when i turn the wheel. especially in the first few minutes after i start driving in the morning. is this a sign for a failing pump?
