power steering fluid
I checked my power steering fluid level when recently doing some work on the car and found the fluid to have a burnt smell. Is this normal fluid level was fine. Looked around couldn't find any other posts on the matter.
If you get under your car, you will notice two lines going to the reservoir. Remove them both and drain the tank and the lines as best as you can. Reconnect the lines and fill with Pentosin 11s. Drive the car for a week or so and repeat the process.
