Power Steering Fluid
Old Dec 1, 2007 | 02:18 PM
vibeuser's Avatar
Default Power Steering Fluid
Guys,
I am looking for some advice as to what I can use for Power Steering Fluid in my 98.5 A4.
Are there products by Castrol, or Penzoil, etc?
Any comments are appreciated.
Old Dec 1, 2007 | 02:26 PM
A4speed's Avatar
Default RE: Power Steering Fluid
audi has different power steering fluid then most cars have, if you use those brands, you will ruin your pump. you need to buy Pentosin powersteering fluid at the dealership or european shops. or if you want to buy online:
http://www.ecstuning.com/stage/edpd/...category=Fluid
Old Dec 1, 2007 | 02:52 PM
wood_e's Avatar
You can use mobil 1 ATF as its properties are nearly the same as Pentosin ch11s. I used it in my A4 with no issues... you need to flush the system though before putting the M1 in.
Old Dec 1, 2007 | 05:01 PM
paaudia6's Avatar
Member
www.pelicanparts.com its like $16.00 there good luck
Old Dec 2, 2007 | 07:26 PM
mschwister12's Avatar
Valvoline Max Life -Powerin Steering Fluid
It won't run you past your budget limit either.
Killuminati
May 23, 2013 09:18 AM
moeron7
Jan 9, 2008 08:09 PM
bronxblaza117
Jan 9, 2008 06:00 PM
thrax982
Mar 31, 2005 10:15 PM
