Power Steering help!!!
Old Aug 19, 2007 | 06:01 PM
kemp_travis's Avatar
Default Power Steering help!!!
My power steering loses power after about a mile and stiffins up REAL bad. Then i let it sit for 10-15 seconds and it regains power for the same distance.
It is also making a "hiss" noise by the steering column and "sounds" like it is losing pressure and then it builds it back up again after i let it sit. and the thing is... NO leaking at all.
Help please
Old Aug 20, 2007 | 06:04 AM
david9999's Avatar
Default RE: Power Steering help!!!
Have you checked the power steering fluid level? Sounds like it is low.
If it is you will need either pentosin 11S or OEM from dealer. Do not use automatic tranny fluid or off the shelf "steering fluid".
Old Aug 22, 2007 | 09:36 PM
no man it was way more than that....
my KoYo steering rack is toast
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
