Power steering pump noise?
Old Sep 6, 2005 | 12:26 AM
juju4uofa's Avatar
Default Power steering pump noise?
Saturday night my car started making a noise when I turn the tires. It only does it when I'm stopped or moving very slowly. I checked my power steering fluid but it was fine. I assume the pump is going bad but just wanted to know if anyone else has had this problem.
Old Sep 6, 2005 | 12:39 AM
david9999's Avatar
Default RE: Power steering pump noise?
I haven't noticed a problem with my car, but that says nothing about your car problems. What kind of noise do you hear?
Growling/grinding is bad. Squeeling could just be worn or loose accessory belt.
Old Sep 6, 2005 | 02:34 AM
onepoint8tee's Avatar
i have a similar issue...So far no one's been able to answer that question with detail. I know what you mean about it though, i have a very very light faint groan accompanied by a little more than "normal" resistance while stoped or at slow speeds. Nothing sounds lose.
Old Sep 6, 2005 | 02:56 AM
david9999's Avatar
Is it coming from the engine compartment or are you talking about the steering column squeeking because the "U" joint on the column has gotten a bit dry.
If that is what you mean, change the angle on the tilt and the telescope to another position. This usually makes it go away.
Old Sep 6, 2005 | 04:08 AM
auDi1.8TQ's Avatar
well, today i was about to post the exact same problem. yup, it sound like a faint groun noise. is it a DIY thing or advance? sorry i dont have that much experience with audis.
Old Sep 6, 2005 | 04:27 AM
juju4uofa's Avatar
Man, there must be something in the air lol. It's definetely coming from the engine compartment. It sounds exactly like a power steering pump that's low on fluid. It doesn't sound like a belt squeal just like everyone else said a light growling noise almost like a howl (??? hell I don't know what it sounds like). I'll check my belts tomorrow to make sure there tight but I don't think that's it. I just wish there was a way to be certain of the issue before I just go replacing stuff. By the way, it sure sucked a little earlier when i took a girl to get coffee and was parallel parking outside of the coffee shop. Nothing gives me more joy than explaing to a girl why my "Audi" is making wierd noises!
Old Sep 6, 2005 | 04:30 AM
one solution is to turn up the music i guess..... just wait until it gets worse until you start replacing shiznat. Check your tire pressure.. If its too low that would cause more resistance, causing more stress on the pump/system, causing noises? I dunno.
Old Sep 6, 2005 | 11:47 AM
CRAZYHAWK's Avatar
I have the same groaning sound. I'm going to spray silicone on the steering wheel joint.
Old Mar 6, 2013 | 01:02 PM
Jbond007's Avatar
Default Steering pump noise
Mine is an A6 and the noise is worse when the temperature outside is below 30 degrees
Old Mar 6, 2013 | 01:15 PM
Jbond007's Avatar
Cool Silly rabbit it's not the column
If the noise is under the hood it's the pump - check the level and if it was the belt it would jerk and be worse if you was turning. The pump is either low or going out!.
