Problem
Old Jan 18, 2007 | 12:56 AM
02tq's Avatar
Default Problem
any time the engine gets loaded it misses like crazy. the check engine light is on have ran codes yet. It's idling rough. No smoke and the plug wires look ok. Anyone have this happen, or guesses on what it might be? It's got me worried.
Thanks in advance
Old Jan 18, 2007 | 01:11 AM
akielb's Avatar
Default RE: Problem
Get it VAG'd we need codes to help. we can guess all day if you want
MAF
Coil Packs
Injectors
Plugs
on and on
Old Jan 20, 2007 | 03:46 PM
02tq's Avatar
Default RE: Problem
P0300 random/multiple cylinder misfire
P0303 Cylinder 3 misfire
Old Jan 20, 2007 | 03:48 PM
onepoint8tee's Avatar
Default RE: Problem
Yes ive had this happen recently and i had 2 cracked spark plugs.
Swap Cyl 3 coil pack with cyl. 4 and see if the misfire follows the coil pack.
Cylinder number arrangement is 1 by the radiator and 4 is firewall side.
Old Jan 20, 2007 | 04:29 PM
02tq's Avatar
Default RE: Problem
switched coil packs still cylinder 3
switched the plugs still cylinder 3
could it be the injectors?
Old Jan 20, 2007 | 04:40 PM
Default RE: Problem
ORIGINAL: 02tq
You cleared the previous misfire codes before all this right?
Old Jan 20, 2007 | 04:47 PM
techbod's Avatar
Default RE: Problem
injector 3 might have an air leak if the code is still coming back
Old Feb 1, 2007 | 03:47 AM
bbigg's Avatar
Default RE: Problem
Did you ever solve the problem
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
