Problem needs to be fixed to get to work at 6am
Old Feb 2, 2008 | 11:48 PM
a4owner's Avatar
Default Problem needs to be fixed to get to work at 6am
Headlights wont come on
no turn signals working
No high beams. (only come on if I pull in lever like to flash the lights)
No horn.
Had an electrical smell burning then turned off car and then when I turned it back on all this stuff was burned out.
Have been in snow a lot recently if that makes any difference
Need help ASAP PLEASE!!!!
Old Feb 2, 2008 | 11:54 PM
mr.cAp's Avatar
Default RE: Problem needs to be fixed to get to work at 6am
did you check your fuses?
Old Feb 3, 2008 | 12:01 AM
a4owner's Avatar
yes I did and they are all good. Anying else that I can do or am I out of luck
Old Feb 3, 2008 | 12:24 AM
pyropenguin's Avatar
Do you have a aftermarket head unit or boost gauge, anything new added to the electrical system?
(i'm not an expert on this, just seeing if i can help at all)
Old Feb 3, 2008 | 12:33 AM
a4owner's Avatar
Everything is stock and its a 2.8 not turbo'd only thing I did was the fake ebay HID bulbs and that was atleast 5 weeks ago and have done a bunch of driving with those since
Old Feb 3, 2008 | 12:43 AM
SkipA's Avatar
Where did the smell come from? Headlight switch? Sounds like something may have gone in the switch. Also possibly in the fuse box other than a fuse. Sniff around and see if you can find the source of the smell.
Old Feb 3, 2008 | 12:57 AM
If something was burning it normally means there was a short somewhere. Like SkipA said, look around and try to find where the smell came from so you can find the source of the problem.
Old Feb 3, 2008 | 01:07 AM
a4owner's Avatar
sort of thru the vents but not 100% sure its all thru the car so it doesn't really help. Is there any other fuses apart from the ones by the side of the door. What are the relays under the dash by the steering wheel? Thanks guys!
Old Feb 3, 2008 | 02:55 AM
CIA's Avatar
CIA
probably a fuse or a relay!!! you must have a short somewhere.
Old Feb 3, 2008 | 09:54 AM
dankhound's Avatar
I would check the ignition switch and the wiring at the ignition switch.
