Problem with tail light
Im having some problem with my tail light. When i turn on my tail light, my right side doesnt light up but when i break, the exact light bold light up. I examine it but i dont see any disconnect spring or burn on it. Any way to fix the problem?
Isn't it the same bulb but has two filiments in it - so one of the filiments is out - just replace the bulb. Also, check your fuses - when you turn on your lights, does your front parking lamp come on(on right side). If its also not lighting up then its a fuse issue, the fuses are sepereated right and left.
