Problem with transmission light
Old May 21, 2007 | 03:51 PM
5starr's Avatar
Default Problem with transmission light
Hi Guys,
I'm new to the board and am hoping someone can help. When I start my car, the transmission light is lit up for all gears: park,drive, neautral, reverse, etc. When I go from park to drive, the light does not move from park to drive.Everything isstill highlighted.My car drives but it doesn't shift gears. It must continually be in 3rd or 4th gear. Every once in a while, when I start the car, the car goes back to noraml operation where the light highlights wahtever gear I'm in. Any ideas what's going on? I hope I describes it well enough to understand. Thanks
Old May 21, 2007 | 05:43 PM
david9999's Avatar
Default RE: Problem with transmission light
You transmission is in limp mode. The only gears that will work are 4th and reverse. You will need to access a real vagcom to pull codes related to the transmission/transmission control unit, have them cleared and post them back here. Could be anything from a bad TCU, bad connector or internal problem with the transmission.
luciddream42186
Jan 25, 2012 08:13 PM
second85
Apr 10, 2009 03:32 PM
04ultrasprt
Jan 10, 2008 05:19 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
