Problem with water in Audi A4 1.9 Tdi
Old Jan 8, 2012 | 07:47 AM
realaikido_vlatko's Avatar
Question Problem with water in Audi A4 1.9 Tdi
I have an Audi A4 1.9 TDi (1996) and i have problem with water coming from the back left seat. The water is coming from the stubb central inside. Where are the outlets from this car? How can I find the outlets? It has a lot of water and i don't know where from is this water. For example I dry out about 5l of water in every driving. Map from the outlets can be very helpfull. Thanks!
Old Jan 31, 2012 | 11:15 AM
bump!
Old Jan 31, 2012 | 12:23 PM
M5S5's Avatar
Tech Certified
Please translate! Stubb central? Outlets?
The most common problems are the sunroof drains clogging up. Another common problem is the drain under the battery tray. Remove battery , battery tray , remove all debris from area & remove rubber plug that clogs with shiitake!
This is usually seen on cars that get parked outside under trees.
One more thing to keep in mind is that the comfort module is under the 2" foam mat & takes a bath.
Find the source of the leak , remove seats & carpet to dry out.
Old Feb 1, 2012 | 12:32 PM
The water probably is coming out from the climatronic intestine, and the carpet is wet. Today i'm going to mechanic and i will keep you informed. If the problem is the climatronic intestine a will just change it with a new one.
Thanks M5S5.
Old Feb 1, 2012 | 12:42 PM
M5S5's Avatar
Tech Certified
Wow , what is a climatronic intestine! Sounds like a Flux Capacitor!
Is that another word for evaporator drain. If so a little shop air from underneith will usually take care of that.
Jul 9, 2012 07:29 AM
driftking8732
Jul 3, 2008 12:38 AM
PKSJeter
Aug 15, 2006 02:19 PM
hofmeister
Jun 3, 2006 01:40 AM
