problems starting after fueling
Old Nov 27, 2007 | 02:40 PM
chaos92287's Avatar
Default problems starting after fueling
every once in a while when i put a lot of gas in the car, it has a hard time starting. it tries cranking for a while, and after about 5 seconds i start pumping the gas pedal and it starts up. any idea what is causing this? it doesn't happen all the time, happens more often when i put a lot of gas in there
Old Dec 1, 2007 | 05:55 PM
dankhound's Avatar
Default RE: problems starting after fueling
Are you overfilling the tank(filling after the pump shuts off)? If soyou may have saturated your charcoal canister. Otherwise id guess that your evap purge valve on the airbox is sticking open causing gas fumes toenter the intake during fueling. Try pinching off the line the next few times you fill up. If the hard starting goes away you have your culprit.
Smokin Tubes
Feb 5, 2012 10:11 AM
mckeenr
Feb 25, 2010 09:46 AM
philippians
Aug 24, 2009 01:11 PM
ripo
Aug 19, 2008 08:19 PM
90gli16v
Jul 29, 2006 01:57 AM
