Problem with ABS and starting engine after fueling up!!!
My ABS light is on and the brake light is flashing. I had the brake fluid change but the lights are still there. In the store they told me that both front brake hoses are cracking, does this has anything to do with the brake light? Any idea about the ABS?
Also everytime y go for gas my engine does not start well if i don't pump the gas pedal several times, then i have to mantain the revolutions in about 2000 for a few seconds and after that no problem....??????? My check engine light is on. Codes: P0411, Po455, 01136, 11138
Secondary Air Injection System Incorrect Flow Detected
Evaporative Emission System Leak Detected (large leak)
You have a problem with the Secondary air pump and/or hoses. Along with the evap system...
With the brake line leaks, I'm betting the hoses (fuel, coolant, vacuum) have never been changed. It seems like it time to to ALL the hoses, lines, and belts.
