pull out the ecu
Old Jan 4, 2007 | 01:42 PM
nyaudia498's Avatar
Default pull out the ecu
i want to reset my ecu. how do i disconnect it?
Old Jan 4, 2007 | 02:29 PM
NuYorka103185's Avatar
Default RE: pull out the ecu
It unplugs just like you would unplug a cable form lets say they back of your pc, x-box or playstation.
Old Jan 4, 2007 | 02:45 PM
Pson's Avatar
Its the little black box on the driverside. You need to pull the black cover off then you will see the little black box clear as day. It takes 4 10mm bolts (5th one is in back but there is another play to pull it out)and you can pull out the ECU and there is two plugs on the back. you unplug them and wait for awhile.
Old Jan 4, 2007 | 02:55 PM
you might have to pull up the weather stripping
Old Jan 4, 2007 | 02:59 PM
new2me's Avatar
Why dont you just unplug the + battery terminal.
Old Jan 4, 2007 | 03:11 PM
acetrebo's Avatar
You dont need to do anything to reset it, besides removing the negative cable from the battery for a few minutes. This will reset the ECU (and your radio!)
Old Jan 4, 2007 | 03:22 PM
Man this ecu reset thing is getting outta hand. I have never seen so many answers all over the place. Remive the ecu, remove the battery, remove the + terminal, remove the - terminal. Who is right?
Old Jan 4, 2007 | 03:26 PM
new2me's Avatar
I reset mine because of a cell that was caused by unpluging a sensor. I dont remember which one i unpluged it may have been the - all i know is the cell went away and has never come back.
techbod's Avatar
its best reset with the proper tools like VAG but removing the neg on the battery will do as long as you have the radio codes, remember ( to unplug the ECU the neg on the battery has to be off anyway ) otherwise you could blow it
bradtyler02
Dec 6, 2010 12:15 PM
blu.suede
Nov 28, 2010 03:17 AM
IronMan111
Nov 23, 2008 12:05 PM
nikoo195
Aug 1, 2007 12:28 AM
wemmington
Jun 12, 2007 08:32 PM
