Putting in new engine / Couple questions
Old May 30, 2007 | 05:17 PM
wemmington's Avatar
Default Putting in new engine / Couple questions
I have a 98 A4 1.8t with a blown engine that I'm about to replace and have a few questions. Im going to replace the clutch pressure plate, disc, and t/o bearing with the kit found here http://cgi.ebay.com/ebaymotors/ws/eB...;rd=1&rd=1
Im also going to replace the timing belt, damper, water pump with the kit found here http://cgi.ebay.com/ebaymotors/ws/eB...;rd=1&rd=1
The guy thats putting in the engine said that he will need to replace some gaskets but the only one he knew of was for the exhaust.
Is there anything else I should replace? Any idea on where I can order the gaskets? First time changing engine any advice?
Also the engine I bought is from a 99 passat. Is that an issue? Do I need to have the ecu reprogrammed?
Sorry for all the questions but I've researched best I can and need some help.
Thanks
Old May 30, 2007 | 06:39 PM
theguy1084's Avatar
Default RE: Putting in new engine / Couple questions
you know the passat came with 10 less hp than the a4. I think that is just a programing thing so that shouldnt effect you. I would replace cam seals and chain tensioner for the cams also. Other than that I would just a good look at all of the hoses while the engine is out and make sure non are bad. Just makes things easier
Old May 31, 2007 | 05:02 PM
wemmington's Avatar
Any other thoughts?
Thanks
Old May 31, 2007 | 09:20 PM
onepoint8tee's Avatar
If its the same engine code everything should hook up the same without any modifications.
Old Jun 1, 2007 | 02:13 AM
Audi A Fizzle's Avatar
just curious, how much did you pay for the new motor, and where did you get it? how many miles?
Old Jun 1, 2007 | 09:13 AM
wemmington's Avatar
Got it from a reputable salvage yard for $1400, longblock, free shipping, 113k miles, 6 month warranty. That was the best I could find.
Old Jun 1, 2007 | 09:28 AM
ironman's Avatar
i hope everythign goes well why do you need to replace the engine what happened, are you planing on doing any turbo upgrades or mods to it b4 you drop it back in??
Old Jun 1, 2007 | 02:01 PM
wemmington's Avatar
ORIGINAL: ironman
I bought the car with the engine blown but did not know what happened until I took the engine out last week and found a hole the size of a softball in the engine block. I prolly wont do much in the way of mods to the engine but a few little things to the body-debadge, clear corners ect.
Old Jun 1, 2007 | 02:23 PM
techbod's Avatar
keep all the reusable part on the old engine apart from the engine block, soft ball hole = con rod through the engine block and we all know what that's caused bypowwwweeeerrrr
S6V10guy
Sep 28, 2014 07:45 AM
horsecrazy8907
Oct 2, 2008 12:26 PM
diablo9861
Sep 24, 2008 01:02 PM
carguytt987
May 17, 2008 06:32 PM
