Quattro Tire Question ?
Old Aug 31, 2005 | 12:24 AM
Shaunp05's Avatar
Default Quattro Tire Question ?
I was doing abit of reading, I cam across something very intresting
On a Q system you have to run the same size tires @ all 4, 16" 17" 18"
I have noticed that some people run the same size tire but with diff Width sizes ...
Front 235/35/19 Rear 245/35/19 for example
The total overall diameter of this tires are and not the same ???
235 been 25.5" and 245 been 25.8"
So in 1 Km the 235 will have 508 Revs
245 will have 502 Revs
Wont this affect the Q system as well as speed calibration as well as ABS operation ?
Old Aug 31, 2005 | 12:27 AM
PandaXpress's Avatar
Default RE: Quattro Tire Question ?
for quattro its better if u dont go staggered
keep the same wheel width and tire size
it will effect the quattro system but most FWD drive people go staggered
Old Aug 31, 2005 | 12:37 AM
headshok2002's Avatar
Yeah, stay away from different diameters... I dont know what the options are though... you might be able to use like a 17 up front, and 18 in the rear... if you had like 235/45/17's up front, and a 225/40/18 in the rear... but it's sort of stupid. Staggered diameters only look good when the overall diameter is different (think corvette).
Umm, as for the different widths... you can get around that sometimes, by changing the profile... like a 225/45/17 vs a 235/40/17... I'm sure you are able to end up with an identical tire diameter... or within a .1 of an inch (which would likely be acceptable -- because different tread wear is acceptable).
Old Aug 31, 2005 | 12:41 AM
PJTocci's Avatar
Do not use differnt wheel sizes on Quattro! Its the dumbest thing you could ever do. [sm=badidea.gif][sm=icon_rtfm.gif]
Old Aug 31, 2005 | 01:02 AM
Shaunp05's Avatar
Nah Dont worry im not planning on puttinf Staggerd Rims on my car
Its just i work at a Firestone Dealer and I was reading the new Fuzion.ZRi
that came out the first half on this year and the same size tire
but with a Difference in Width can make a Huge diffrence in the turning
radius of the tire
And if you change the profile of the tire say with a 35, 40 profile
you will affect axle wind up in ur Q system
Pedja
May 19, 2011 02:37 PM
markymarc
Apr 7, 2011 06:24 PM
rhessballin@gmail.com
Aug 21, 2010 11:21 AM
sirfalconx
Nov 22, 2007 09:27 AM
mach6261
Apr 25, 2006 04:01 PM
