question about rubbing issues
Old May 12, 2005 | 01:58 PM
SlowWagon08's Avatar
Default question about rubbing issues
My front rubs when turning slowly or when going onto a driveway and my rear rubs when i hit bumps and dips.
Would you guys recommend rolling the front fender and ajusting the rear camber when rubbing or should I just change my suspension to sport springs instead of race?
TIA
Old May 12, 2005 | 02:01 PM
PandaXpress's Avatar
Default RE: question about rubbing issues
is it rubbing on the inside or of the out side fender
Old May 12, 2005 | 02:03 PM
Its the inside cause when i jacked it up, i felt the inside liner getting ripped up.
black b5's Avatar
wow, tuckin 20's on the avant.
i think fender rolling will be the best option.
dont adjust the rear camber out of spec.
nice ride btw
Old May 12, 2005 | 02:05 PM
well i know if i adjust the rear camber it'll unevenly wear the tires which is something i don't really wanna do but if it helps in the rubbing issue then i'll consider it.
thanks for the props.
i duno about the cambering you might just mess up your tires
Old May 12, 2005 | 02:08 PM
what should i do about the back then?? should i just take out the liner and hope thats the extent of the rubbing?
Old May 12, 2005 | 03:36 PM
black b5's Avatar
i would recommend that as a start. check the liner when you take the wheel off and look to see what area it is rubbing against
Old May 12, 2005 | 03:59 PM
nice! i'll try that this weekend and see what happens...thanks!
Old May 12, 2005 | 11:45 PM
turbo's Avatar
I have a B6 4 door and you cant rool the fenders in it because there is no lip to rool.
I am not sure if yours is the same.
Try to cut or take out fender liner.
