Quick ECU question...
Old Sep 19, 2007 | 12:53 PM
secmil's Avatar
Default Quick ECU question...
So let's say that I put an ECU from the same model engine in my car that has a different part number than the ECU that I took out of my car...
Is it possible for the ECU to damage any part of the engine if I'm only driving maybe 20 miles a day over the next 3 days?
Tried searching but didn't find much related to what I want to know...
Thanks for any help!
Old Sep 19, 2007 | 12:54 PM
cincyTT's Avatar
I'm make believe
Default RE: Quick ECU question...
the ecu code needs to match.
Old Sep 19, 2007 | 01:00 PM
secmil's Avatar
I know that... I want to know why, though...
What exactly could break and how?
Old Sep 19, 2007 | 01:04 PM
cincyTT's Avatar
I'm make believe
it most likely wont even let the car turn on. Differnt ecu's have differnt codes/parameters. You can try it, but i would return/sell it
Old Sep 19, 2007 | 01:06 PM
akielb's Avatar
he talking about softcodeing - manual, auto, fwd, awd - all combo's have different #'s you'll need a vag-com to change this. if the other car is the same all around there should be no problem
Old Sep 19, 2007 | 01:12 PM
secmil's Avatar
OK, well the other car was the same all around, 1998 a4 quattro 5spd 2.8l 30v. And I have a vag-com, so, yeah...
The ECU is plugged into my car, and it does start. I have run Vag-COM logs and there's some weird stuff going on (throttle controller malfunction code), but if it won't mechanically damage the vehicle in any way I'm perfectly fine living with the jerkiness and probably shitty gas mileage for 3 days...
It sounds like the ECU will only affect the way the car behaves on a broader scale and won't permanately mess anything up?
I know it's not the best idea and all, but if it won't break anything than I'm fine with it.
If anybody has any more info on the destructive powers of the ECU, by all means...
I can describe the issues a little more in depth and/or post a vag-com log if anybody wants to know what's happened so far in a bit more detail... Let me know
Old Sep 19, 2007 | 04:08 PM
akielb's Avatar
did you do a throttle body alignment? - turn the key to the on position - not started - and leave it there for a couple minutes - turn it off then start the car -see if that helps
jmcdowel
B7 Models
Jan 6, 2014 05:48 PM
grimace132
Nov 21, 2012 08:10 PM
DustanS
Jun 10, 2011 10:45 PM
khj677turbo
Dec 23, 2007 06:00 PM
ThePapaCMan
Apr 11, 2007 02:26 AM
