R1 sounds like a BOV
Old Oct 18, 2007 | 09:40 PM
cincyTT's Avatar
I'm make believe
Default RE: R1 sounds like a BOV
ORIGINAL: Leifer
ORIGINAL: cincyTT
told you before and ill say it again.... PRESSURE TEST. Onepoint8tee will help if you need it.
We DID pressure test the system? Or is what you're talking about something different. I haven't looked for onepoint8tee's thread regarding it yet.
how can you say DID in caps and then ask a question? But no, you didnt.
Old Oct 19, 2007 | 12:36 AM
Leifer's Avatar
ORIGINAL: cincyTT
ORIGINAL: Leifer
ORIGINAL: cincyTT
I say I did because I went and got my boost pressure reading today (while driving). I don't know if you read the first part or not, but I'm not losing any boost. I'm not sure if that's what you meant when you said "pressure test"
Leifer's Avatar
****. Wrong button. Edit and quote are too close [:@]
Old Oct 19, 2007 | 12:50 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: Leifer
you could be making the same psi, but the turbo could be pushing more psi to make it. I would still pressure test the system and find the leak. But if your not loosing boost, check the recirc hose to see if there is a tear/hole. That would make that noise.
Old Oct 19, 2007 | 01:11 AM
Leifer's Avatar
ORIGINAL: cincyTT
ORIGINAL: Leifer
I tried searching for a "pressure test" thread, nothing came up. Do you know off the top of your head what it's called?
Old Oct 19, 2007 | 01:12 AM
cincyTT's Avatar
I'm make believe
not sure, just know onepoint8tee has one and im sure there are others.
Old Oct 19, 2007 | 01:28 AM
Leifer's Avatar
ORIGINAL: cincyTT
Kay, I'll bug him. Thanks for the help. If I end up not having a tear or a break, it's okay. I have a BOV like you [sm=wootwoot.gif](not being a sarcastic *******)
Old Oct 19, 2007 | 01:30 AM
  #18
cincyTT's Avatar
I'm make believe
you can run what you want, isnt hurting my feelings either way. i barely notice mine now. Plus im going back to a dv when i get my car back and make my ic. 34mm > 25mm....lol. Patty at forge is tempting me with a 40mm forge dv.
Im as much of a valve ***** as power *****.
Old Oct 19, 2007 | 01:40 AM
  #19
Leifer's Avatar
ORIGINAL: cincyTT
I'm not trying to. I like BOV's on a performance-tuned Audi; it shows purpose and function. Maybe after all of my performance-gain goals are done with, I'll throw a BOV on the car.
Old Oct 19, 2007 | 01:46 AM
  #20
cincyTT's Avatar
I'm make believe
50mm tial FTW. But you need a min of a 300whp though, otherwise it makes life suck
