Radiator Flush
Old Feb 18, 2007 | 10:31 PM
lfab500's Avatar
Default Radiator Flush
I'm going to flush the radiator in my 1996 A4 soon. Do you have to bleed air out after filling with G12 and if so from where? Thanks...
Old Feb 19, 2007 | 02:59 PM
SouRce4's Avatar
Default RE: Radiator Flush
how many miles are on the car? cause my dad was telling me that if your car is older and has some miles on it... it might not be the greatest thing to do unless REALLY Needed. its hard to explain but mab i can by givin an analogy. its like an old cespool. the wastes from ur house fill up this pool and basically hold the sides of the walls and stuff up... if u drain it out totally u can run the chance of having the pool collaps. that iisnt really that great but what im saying is if the car doesnt have any coolant leaks right now... if drained it can cause problems while empty...
Thats what my dad told me and i pretty much trust him since he used to build cars from the ground up =]
Old Feb 19, 2007 | 04:32 PM
CRAZYHAWK's Avatar
That is not true for cooling systems. They must be clean to work properly.
The water needs clean antifreeze for its lubrication.
Old Feb 19, 2007 | 07:46 PM
Karl's Avatar
isnt G12 a lifetime coolant anyways.. why are you flushing it?
Old Feb 19, 2007 | 08:08 PM
CRAZYHAWK's Avatar
It is good for 80 or 90K mi.
Old Feb 19, 2007 | 08:21 PM
Karl's Avatar
ahhh gotcha
Old Feb 20, 2007 | 12:11 AM
lfab500's Avatar
108,500 miles. The expansion tank has a small leak on the top.I am going to replace it, so I thought I would go ahead and flush it and add the G12 plus...
Old Feb 20, 2007 | 12:30 AM
Trey25's Avatar
No you wont have to bleed air, just run the engine with the cap off and add G12 as needed.
Old Feb 20, 2007 | 12:31 AM
Karl's Avatar
there will still be air in the system that will require bleeding
rowesouth
Jul 10, 2014 07:20 AM
shady927
Sep 20, 2008 10:14 AM
Restrepo
Oct 18, 2007 12:30 PM
pv1127
Jul 25, 2007 08:12 PM
apg96
Mar 5, 2006 10:38 PM
