Radio display flickering
Old Oct 25, 2006 | 10:11 PM
therippa's Avatar
Default Radio display flickering
Lately my symphony 2's display has been been kind of flickering at night when I'm at a stop...it goes dim then bright then dim then bright.
Any ideas before I take it to the dealer?
Old Oct 25, 2006 | 10:29 PM
xAUDIx's Avatar
Default RE: Radio display flickering
Do you have subs?
Old Oct 26, 2006 | 12:53 AM
therippa's Avatar
ORIGINAL: xAUDIx
Do you have subs?
Nope...nothing that would be drawing too much juice. Also, it's just the radio that's doing this, not the lights for the climate control or anything.
Old Oct 26, 2006 | 12:58 AM
xAUDIx's Avatar
Hmmm, are you the first owner of the car? perhaps the previous ower rewired something back there that is faulty now. Try checking back there to make sure everything is in order
Old Oct 26, 2006 | 02:50 AM
dankhound's Avatar
The radio has a light sensor that adjusts the light output of the radio based on the light input to the sensor. The snesor is a small circular dot on the face of the radio(there may be two of them). I have a feeling this is malfunctioning. You can try covering it with your finger while it is malfunctioning. That should put it in the bright mode. You may also want to try cleaning it. It may just be dirty. If covering it and cleaning it dont help youll probably need a new radio.
Antony1968
Dec 10, 2014 02:31 AM
stroker7.3
Mar 8, 2011 11:51 PM
guru_ck
Sep 9, 2007 01:17 AM
splixxx
May 8, 2006 08:05 PM
splixxx
Dec 25, 2005 02:51 AM
