ran through a flood!1997 1.8t
Old Apr 18, 2007 | 04:41 AM
mrjaykeys's Avatar
Default ran through a flood!1997 1.8t
i recently ran across some problems with my car during a flood.i hit an unexpected puddle which was pretty deep during a storm.i managed to drive pass through the puddle but after later noticed my car began to drive unusual.i pulled to the shoulder assuming that a tire blew, but all were intact. then i noticeda sound in the front passenge assuming my suspension was damaged. the car was able to turn on and off that produced a bad smell.its been three days and now the car no longer starts.im not sure what the problem is?blown engine?spark plugs?etc? any feedback would be much appreciated
my email is tactikmzm@yahoo.com
Old Apr 18, 2007 | 04:44 AM
Jeff's Avatar
Zombie Defense Force
Default RE: ran through a flood!1997 1.8t
hydrolock. you probably sucked water into your motor. does it crank over or do anything?
Old Apr 18, 2007 | 09:04 AM
x1rider's Avatar
ORIGINAL: Jeff
2nd that, not good if you hydrolocked.
Old Apr 18, 2007 | 02:35 PM
SAudi's Avatar
try this, get some starter fluid( auto parts stuff not BBQ stuff), seafoam and oil and filter, and possibly a new air filter. replace the filter and spray started fluid into the intake it should start at that point, then run sea foam through the system to absorb as much moisture, then change oil to rid any contaminated oil. this is what we did when my mom STOPPED in a deep puddle.
Old Apr 18, 2007 | 02:50 PM
david9999's Avatar
Not hydrolocked, unless you drove through 4 feet of water. In which case your car would have stalled immediately. check for codes. It could be wet wires or a short circuit on some sensors
kjallday16
Aug 19, 2011 07:18 PM
crooklynyc
Jul 13, 2010 07:04 PM
Deadsmart
Jun 16, 2010 09:54 AM
droo587
Oct 26, 2006 08:05 PM
