Rattle in the wheel
Old Feb 2, 2006 | 10:03 PM
a4vt's Avatar
Default Rattle in the wheel
I am looking for some help with my 98 a4 Avant. When I drive over small bumps there is a rattle coming from the front drivers side of the car. There is no differance in the way the car handles, like if there was a ball joint or barring issue.
I am very familiar with ball joints, I have replaced all of them 8 in total. As well as barrings 2. The car has 124,390 mi. I rack them up doing around 100 miles a day. A friend told me it could be a loose strut mount, (do audies have struts).
Unrelated. Does any know a good placs to get center caps. I have had no luck at local dealers (with in a good price range)
Thanks
Old Feb 3, 2006 | 12:12 AM
david9999's Avatar
Default RE: Rattle in the wheel
The rattle is either tie rod/ tie rod end, bad control arm(s) or loose strut mount.
Check the wreckers (DADS auto, or shoksan) for used parts.
Old Feb 3, 2006 | 01:06 PM
a4vt's Avatar
Thanks, I will have it checked
Old Feb 3, 2006 | 01:38 PM
Yuikio's Avatar
Could be the strut mount, or it could be that the brake caliper is a little loose. I was having a weird clunking rattle from the passenger side front wheel, and I went to check, tightened the bolts that hold the caliper to the carrier and haven't had the rattle since.
Old Apr 28, 2007 | 02:35 PM
V_i_D's Avatar
I'm having the same problem, and I've had my car back to the shop 3 or 4 times. It started out as a barely audible sound but now it's almost constant. The only difference in my problem is that the sound is silenced when I apply the brakes. Does that help narrow the problem down?
So far I have a small list of tie rod, tie rod end, control arm, and strut mount.
rooftoplounge
Apr 16, 2009 12:04 AM
Newaudilover
May 21, 2008 11:58 AM
TurboedA6
Aug 7, 2007 04:16 AM
Muchnik
May 10, 2007 04:53 PM
dragondesigns
Feb 14, 2006 01:45 PM
