rattling noise when clutch is released, please help????
Old Feb 25, 2007 | 10:34 PM
A4Rollin's Avatar
Default rattling noise when clutch is released, please help????
so today I was driving home and a reaccuring problem ive had has gotten worse. this happened to another audi I had but never figured it out. I have an aftermarket clutch and flywheel, i believe flywheel weighs 13 or 14 pounds. When i drive my car it runs and shifts perfectly fine. However, say im slowing down from 30mph and i take my car out of gear and release the clutch, when the rpm's drop to 3000 to 1500 i hear this rattling noise. Almost like something is loose..... Today I noticed that when it IS in gear, it makes the same noise when i accelaerate hard (only through 1500 to 3000 rpm's). Especially when im in second and i start going from say about 10mph it does this, almost with every gear... My last car it did this but worse and I thought it might have to do with the throw-out bearing OR faulty flywheel maybe but it didnt solve the noise.......anybody please help me out!!!
Old Feb 25, 2007 | 10:54 PM
jonus079's Avatar
Default RE: rattling noise when clutch is released, please help????
before i replaced my clutch/transmission my car would rattle really bad when i was just sitting idling. funny thing is the previous owner said he drove it with that rattling for as long as he could remeber. anyway when i pulled of the transmissionthe t/o bearing looked fine. i replaced the entire clutch and havent heard the noise since.
theres is a very very slight chance it was my transmission rattling. i replaced that because it would grind really bad in first gear and did the clutch while i had it all apart. i dont really know what to say but its sounds like its the t/o bearing.
Old Feb 25, 2007 | 11:03 PM
A4Rollin's Avatar
yah im thinkin about takin it apart again but want to hear what everyone has to say before i do. t/o bearing is the only thing i can think of
Old Feb 25, 2007 | 11:07 PM
Belligerenceā„¢'s Avatar
another possibility could be the pilot bearing in the flywheel.
Old Feb 25, 2007 | 11:55 PM
A4Rollin's Avatar
if the pilot bearing in the flywheel is bad, the company should replace it, i would hope
Old Feb 26, 2007 | 12:03 AM
auditech79's Avatar
I have run across this several times when upgrading to RS4 clutches on S4 transmissions, the mail problem with them is either the pilot or throwout bearing, but sometimes if you have a 1.8 liter people forget to put the metal shim back in between the engine and transmission and because its so thin on an 1.8 liter it will bolt up fine but will trash the bearings and possibly the tranny.
Old Feb 26, 2007 | 12:26 AM
A4Rollin's Avatar
hmmmm........first time hearing this, makes sense a shop wouldnt put it on cause of how thin it is
Old Feb 26, 2007 | 01:45 AM
ORIGINAL: A4Rollin
yeah, I would think they'd have to, unless they can prove it was through some wrongdoing of yours. that'd be pretty much impossible, so yeah they'd probably replace it.
it sounds like the shop didn't put that thin metal shim back in... in which case if your tranny's f*cked, they should have to pay for a new one.
Patrick69
Jan 11, 2014 04:02 AM
adampaulcrickmore
Jan 11, 2012 11:40 AM
AlenK
Feb 2, 2011 09:59 PM
quiktsi
Dec 13, 2010 08:57 PM
edge19lw
Dec 21, 2006 07:47 PM
