Rattling noise when in Drive
Old Jul 15, 2006 | 09:14 PM
yellowa4's Avatar
Member
Default Rattling noise when in Drive
Hey everybody!
I'm experiencing a weird problem that i noticed this morning.
When I am in drive or reverse I hear a rattling or ticking (it's quite rapid). I noticed it when my brakes were applied while stopped at a stoplight. I'm not sure whether it's coming from the engine or the transmission.
Here were my observations:
The ticking was most noticeable while in drive or reverse (basically in gear) and the brakes applied
I'm positive I can hear it while moving and the brakes are not applied
The sound is not occuring when in neutral or in park (with and without the brakes applied)
I have a 2000 A4 1.8T Quattro Tiptronic
Does anybody have any ideas or has anybody experienced this issue?
Thanks
B
Old Jul 15, 2006 | 09:31 PM
TeeterTawter's Avatar
Default RE: Rattling noise when in Drive
check ur exhaust, hanger might have come loose or somethin.
Old Jul 15, 2006 | 09:53 PM
toyolla86's Avatar
it could be the exhaust but that would still make noise in nuetral and park.
id say tranny or drive train/ shaft
since its only when in gear what about stopped at a light but still in gear
Old Jul 15, 2006 | 11:26 PM
david9999's Avatar
Sounds like exhaust or a loose honeycomb in the catalytic converter.
Old Jul 16, 2006 | 12:45 AM
yellowa4's Avatar
Member
Thank you very much gents!!!
I'll have a lookie... how can one fix the loose honecomb in the cat? Just asking? Will I need a new cat?
B
Old Jul 16, 2006 | 11:48 AM
david9999's Avatar
Can;t be fixed, however, if you are in the US, emissions equipemnt has an extended warranty. I believe it is 8 years and 80K miles,
Old Jul 17, 2006 | 05:14 PM
yellowa4's Avatar
Member
Thanks!
Just noticed another sound in conjunction to the one i described earlier:
On the slow acceleration and deceleration I hear somewhat of a grinding and whining sound (like scraping tin). I know that I have to replace my wheel bearings (this weekend) but the sound does not seem to be the wheel.
I hear the sound when I hit the gas and when I apply the brake.
I don't think it's the belts because I had them replaced last summer (90000KM).
Has anybody been through this before?
2000 1.8T Quattro Tiptronic
Thanks so much!
B
Old Jul 17, 2006 | 06:54 PM
seahawkfan94's Avatar
Does it rattle when you're in neutral and revving??? I've gone to the Audi Stealership 6 times now to get my rattling fixed on the USP. I found out it's a metal sleeve somewhere in the exhaust that is loose on the ultra-sports. So I think they'll finally check into it more. If you hear it when revving, it could be a leak when punching the gas, and also when the car's winding down to idle (the back-pressure). Keep us updated and good luck.
Old Jul 17, 2006 | 07:22 PM
yellowa4's Avatar
Member
The rattle is not audible when in neutral and in park. I'm hoping that it is something minor but so far I'm not lucky in that manner.
In the past 24 months I've spent $2800 CDN in various repairs (not maintenance).
Thanks for your help!
B
Patrick69
Jan 11, 2014 04:02 AM
AlenK
Jun 30, 2011 11:18 AM
AlenK
Feb 3, 2011 01:39 AM
edge19lw
Dec 21, 2006 07:47 PM
thizzwatitiz
May 23, 2006 12:06 AM
