is this really better than k04???
Old Oct 16, 2007 | 07:11 PM
cacaro's Avatar
Default is this really better than k04???
this item on ebay claims to be better than the k04 setup, can someone confirm this cus my turbo is shot and if this is true im going to rebuild with this setup and do an aggresive k04 program chip.
http://cgi.ebay.com/ebaymotors/K03-K...spagenameZWDVW
Old Oct 16, 2007 | 07:15 PM
oneg's Avatar
Default RE: is this really better than k04???
it seems like its a diy build a ko3 to ko4 specs type deal.
Old Oct 16, 2007 | 07:17 PM
stanman309's Avatar
this is just my opinion but for almost 300$ couldnt u buy a turbo with more potential than the k04. I have not been involved with audi's before but i would think that the stock turbo on our 1.8's doesnt have a lot of room for real high performance. i could be totally wrong but before buying a fleabay kit i would do more research on other alternatives.
my 2cents
Old Oct 16, 2007 | 07:39 PM
turbo kraut's Avatar
Tech Guru
i don't know what year your car is, but i would look into a gpopshop ko4 over that unknown company
Old Oct 16, 2007 | 07:44 PM
chaos92287's Avatar
this isn't a turbo. its the turbo internals. so you would have to take yours apart and put these in. which i doubt you'd be able to correctly balance everything and do it right. (i know i couldn't). dont go to ebay for a replacement turbo. half of them are glued together pieces of ****
Old Oct 16, 2007 | 07:50 PM
hiwords's Avatar
and the other half are made out of tin
Old Oct 16, 2007 | 08:45 PM
oneg's Avatar
ORIGINAL: chaos92287
kinda what i was gettin at. go for their high quality electric, plastic supercharges instead.
Old Oct 17, 2007 | 11:52 AM
widgget's Avatar
ORIGINAL: stanman309
my 2cents
A turbo bigger then a k03 is going to cost you $800 - $1500 depending on what you are looking for not including any thing else. and yes the 1.8t has more then enough room for some very powerful setups. stock internals will handle up to 300/350hp once you go over that you need to replace the rods and whatnot, you will then be good for 500ish, heard of people going higher. just look aorund on the site, you'll be amazed what the 1.8t can do with a little work.
Old Oct 17, 2007 | 12:19 PM
cincyTT's Avatar
I'm make believe
It increases the inducer and exducer to increase the trim level which intern increase the amount of air it can flow. This should increase the hp rating a small amount. There is a way to rebuild the turbo yourself by doing it in certain steps so it doesnt go out of balance. I wouldnt expect huge gains, but a noticeable gain over a regular ko4 "upgrade"
