Rear 12 Volt Source
Old Mar 18, 2005 | 02:13 PM
Hecareth's Avatar
Default Rear 12 Volt Source
Is there a rear power source that I can connect a Sub to? I am trying to connect a basslink T without going to the battery.
Old Mar 18, 2005 | 02:21 PM
Jestnomen's Avatar
6th Gear
Default RE: Rear 12 Volt Source
Eh you are going to want to run a line. There is no 12V power source with low enough guage wire to achieve what you want.
Old Mar 18, 2005 | 02:26 PM
clconversion's Avatar
hahaha no you need to run a power wire from the battery
Old Mar 18, 2005 | 07:38 PM
A4NightRider's Avatar
fun fun fun...glad mine was done for me...
Old Mar 18, 2005 | 07:42 PM
Jestnomen's Avatar
6th Gear
Meh, it's pretty easy to do. Only takes a half hour or so.
Old Mar 19, 2005 | 03:13 PM
mainer's Avatar
where is the easiest place to run it??
Old Mar 19, 2005 | 06:16 PM
brrman's Avatar
in through the ECU box, down under the knee bolster, up along the side of the car under the foot trim.
MAKE SURE YOU FUSE IT
Old Mar 19, 2005 | 08:58 PM
Shaunp05's Avatar
Fuse it close to the Batt, 4AWG wire can pretty much handle 90% of the systems out the, its a good base to start with.
Theiceman
Jun 28, 2010 07:51 AM
ryann
Aug 17, 2008 10:40 AM
matthias2986
Apr 23, 2007 11:27 AM
Colin519
Sep 19, 2006 04:49 AM
a4autocrossr
Dec 20, 2004 04:23 AM
