Rear Brakes Leaking with E-Brake On
Hi folks, my wife's car is diiiiieeeeing.... Seems like it's one thing after another. We just changed the clutch, timing belt, water pump, etc. for $1800. Granted the car has 135k miles.
So we realize now that the rear caliper leaks brake fluid when, and only when, we engage the e-brake.
Question is, what part do I need to fix this? I can rebuild the calipers, but I need to know what part is needed.
Thanks,
Armand
Thanks,
Armand
Thanks for you reply. I did take the wheel off. This is how I come to realize that the caliper is leaking towards the back - where the e-brake engages. I just don't know which seal (if any) to buy or where to buy them from.
ORIGINAL: duburban
I'm curious about this too. You can buy a new caliper for 100 from ecstuning.com. Not a bad price...
ORIGINAL: dafrazi
Isn't the Ebrake cable actuated?
Does anyone have part numbers on the seals that need to be replaced?
The cable pulls on the lever which causes the piston inside the caliper to twist and contact the pads.
The only seal that would need to be replaced is the seals within the piston and the boot. Like I said, it's easiest to get a rebuilt caliper and forget about it.
o_a_ravi@hotmail.com
Aug 30, 2012 07:05 PM
2000_S4_BITT
Jan 26, 2009 02:58 PM
