Rear final drive seal replacement
Old Nov 6, 2007 | 03:52 PM
PhatPipe's Avatar
Default Rear final drive seal replacement
Anyone on here ever replaced the three seals in the rear diff? (Input and 2 outputs) Got any pointers?
Old Nov 6, 2007 | 05:20 PM
Fier Ringe's Avatar
Default RE: Rear final drive seal replacement
You need to get the factory seal installer tool number 2062 for each of the side seals. The front of the rear differential needs several more and is a pain to do. What year is your car? If it is 96-01 then it is pretty easy. Lift the car and take out upper control arm bolt to tilt wheel out and unbolt axle from diff flange and diff flange from diff and pry out seal, clean up and install new seal. Top off fluid when you are done. You will need a 8mm triple square, a torx socket and a 10mm allen socket as well as seal installer and a way to get the new fluid into the side of the diff.
Old Nov 6, 2007 | 08:27 PM
david9999's Avatar
Alternatively, you can just check the gear oil level, and top it up once a year if it isn't leaking badly.
Old Nov 6, 2007 | 09:30 PM
PhatPipe's Avatar
It's a 2001 A4 1.8T QM Sport...
Are the authentic tools absolutely necessary or can I make do with something else in my modest tool collection?
Thanks
Old Nov 6, 2007 | 10:16 PM
wood_e's Avatar
IIRC there's a write up on this at audiworld
Old Nov 7, 2007 | 09:55 AM
PhatPipe's Avatar
Got a url to it? I searched to no avail.
Old Nov 9, 2007 | 11:47 AM
PhatPipe's Avatar
For everone else's benefit, hereare write ups on Audipages:
http://www.audipages.com/Tech_Articl...placement.html
Old Nov 9, 2007 | 11:58 AM
auditech79's Avatar
Thats an A8 which is a hell of a lot harder to do that an A4 rear prop seal.
Just pop off the shaft and let it hang, take out the center torx bolt and pull out the drive axle flange, use a pry par or screwdriver and pry out the old seal. You are supposed to use a seal installer to align the new seal in correctly buy you can lightly tap it back in with a rubber mallet.
Mark83
Audi Q5
Jun 27, 2013 02:04 PM
obryan44
Nov 22, 2012 08:47 AM
GregL
Aug 27, 2010 11:14 PM
Sport4Auto
Dec 27, 2007 09:49 PM
wings7351
May 9, 2007 10:15 AM
