rear sway q...especially for moderator
Old Mar 30, 2005 | 10:36 PM
awol's Avatar
Default rear sway q...especially for moderator
Do you guys have any links on the installtion of a Quattro Sport front and rear sway bar on a FWD?
Old Mar 30, 2005 | 10:46 PM
Jestnomen's Avatar
6th Gear
Old Mar 30, 2005 | 11:10 PM
awol's Avatar
Default RE: rear sway q...especially for moderator
I knew it would be you that would know...thanks man...
Old Mar 30, 2005 | 11:19 PM
Jestnomen's Avatar
6th Gear
np
Old Mar 30, 2005 | 11:23 PM
awol's Avatar
I am not even sure if this can be done...it seems the FWDs do not have a rear sway so I will need bushings and mounting screw...
Old Mar 30, 2005 | 11:35 PM
Jestnomen's Avatar
6th Gear
Neuspeed sells a rear sway bar for a FWD.
Old Apr 7, 2005 | 10:00 AM
awol's Avatar
So I am guessing then that no one has actually tried installing an OEM sport rear sway bar to a non-sport FWD...Looks like I'll be calling the Stealership for some hardware...
Old Apr 7, 2005 | 10:19 AM
Jestnomen's Avatar
6th Gear
Not on this forum.... At least save some money buy buying at worldimpex.com.
Old Apr 16, 2005 | 05:29 PM
awol's Avatar
Worldimpex has almost nothing for this car for the suspension. But after looking at the suspension geometry I can not imagine that anyone makes a rear sway bar kit for the FWD becuase it is a solid axle rear. I have looked at all the info you have give and there does not seem to be anything actually for the FWD only for the q cars.
Well putting the sport front on should reduce body roll with a small loss in understeer.
We will see.
Old Apr 16, 2005 | 05:59 PM
David_K's Avatar
Why would you need a moderator to answer this question? Moderators arent chosen for their knowledge about audis. they are chosen because they are responsible and can be trusted to enforce the rules of the forum. your just lcky to have a very bright administrastor.
