relay question
Old Apr 6, 2005 | 07:15 PM
Jackson's Avatar
Default relay question
Can anybody tell me where the rad. fan relay is on a 97' A4Q 2.8
and how may sensors or switches go with the cooling system (some thing that would kick on the electric fan)
Thanks
Old Apr 6, 2005 | 07:18 PM
cukilo's Avatar
Default RE: relay question
Are you sure that the fan is working and that the temperature sensor is working before you replace the relay?
Old Apr 6, 2005 | 07:22 PM
BFlan2001's Avatar
here's a writeup for replacing your coolant temp sensor......40 bucks at the dealership....or ~10 bucks from ECStuning.com
EDIT: there was a similar problem posted yesterday i believe....it may very possibly be your thermostat...
Old Apr 6, 2005 | 09:44 PM
BFlan2001's Avatar
just found this write-up on our own forums....thanks to imola...maybe someday we'll have a bigger write-up section than aw..
Old Apr 6, 2005 | 10:30 PM
david9999's Avatar
Most likely the fan is burned out. ON my year, the fan only runs if the AC is on.
But first check the fan fuse. On my year, there is a 40 amp fuse behind the driver's side knee bolster. Your's may be located elsewhere. Check and see if it is blown and replace. If the fan then starts when the AC is on, but dies and blows the fuse, you need a replacement fan.
sandman7
Mar 31, 2015 05:06 PM
mason13
Jul 20, 2013 11:06 AM
browny355
Jul 15, 2011 07:00 PM
CcL
Feb 28, 2009 11:44 PM
BFlan
Mar 10, 2005 09:51 PM
