Remote turbo setup...Illegal??
Old Apr 20, 2007 | 05:28 AM
sean1.8t's Avatar
Default RE: Remote turbo setup...Illegal??
ORIGINAL: cincyTT
ORIGINAL: sean1.8t
but 2.8L is not enough displacement to really take advantage of a remote setup..
I have seen a rear mounted integra, what does displacement have to do with anything? As long as you still have exhaust velocity you are good.
exhaust gas cools as it moves down the exhaust, this means that by the time it reaches the turboat the back of the car it has a slower velocity. now you have to take in the fact that there is even more IC pipe back to front of the car before the charge air gets to the cylinder. this makes it less efficient then a turbothat has a very short runner manifold and a short IC pipe to the TB.. this is what the rear mount system has against it. and that is with engines twice the size as a 2.8. it will work, it will have enough exhaust gas velocity to turn a turbine.. but it just won't have as good as results as the larger 5.7+ liter V8s do..
Old Apr 20, 2007 | 05:35 AM
cincyTT's Avatar
I'm make believe
Any GOOD turbo system should have the turbos shortly following the enigne, of course. You and i both know that. STS claims far lower intake temps than a normal tubo setup can provide from the extra distance. I have seenthe install of a system on a corvette on tv and they only claimed 1 or 2 psi drop to the tb from a remote turbo and only needing a small ic due to heat loss through the charge pipes. Not my ideal setup, but better than a N/A 2.8/3.0.
Old Apr 20, 2007 | 05:44 AM
sean1.8t's Avatar
maybe, but not better than a 3.2L VR6-T swap
Old Apr 20, 2007 | 05:48 AM
cincyTT's Avatar
I'm make believe
LOL...SWEETTTTTT!!!1 [sm=hail.gif]3.2T
Old Apr 20, 2007 | 06:04 AM
BadLuckAudi's Avatar
or 3.2TT
ORIGINAL: cincyTT
Old Apr 20, 2007 | 07:13 AM
sean1.8t's Avatar
^^no buddy, single turbo 3.2 ftw
here's one of my favorite video's explaining it
http://www.eiptuning.com/eip/video/R...WD_DYNO_02.mpg
Shake&Bake
Oct 5, 2011 10:00 PM
drev500@aol.com
Mar 12, 2009 02:24 PM
1 point 8 tee
Nov 16, 2005 02:20 AM
Riegertuned
Aug 16, 2005 11:31 AM
