Remove the n75, Fuel Cut?
Old Aug 22, 2006 | 07:27 AM
ranzor's Avatar
Default Remove the n75, Fuel Cut?
If I remove the N75 and connects the turbo to the wastegate directly, Is there any bad things that can happen then?
Will the Fuel Cut work when the n75 is gone?
am thinking about using a boost controller the get about 0,9bar i boost.. (whit the n75 gone i have 0,5)
sould i leave the n75 plugged in elec.?
The car has a chip for 200hk... and a turbo for 350hk max..
[IMG]local://upfiles/19653/1AD0A084DEEB4745A47C28ED3C50EE26.gif[/IMG]
The car is:
Audi A4 1,8Tq -96
Old Aug 22, 2006 | 10:06 AM
RLB6's Avatar
Default RE: Remove the n75, Fuel Cut?
If you choose to use a boost controller, remove the vacuum/boost lines form the N75 valve and route them to the boost controller BUT leave the N75 wire harness plugged in so that you don't get errors and the check engine light.
Also, you won't be able to boost too much over what your chip is set for or else your car will go into limp mode.
Old Aug 22, 2006 | 03:49 PM
onepoint8tee's Avatar
Oh you have a chip.. Well dont turn it up past what the chip boost is. There is no point.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
Luisthehomie
Oct 1, 2012 05:24 PM
dukesean
Mar 22, 2011 05:59 PM
